Re: 966 charging or ground problems
Posted by El Toro on June 02, 2012 at 07:55:12 from (108.3.225.57):
In Reply to: 966 charging or ground problems posted by 4840JD1660IH on June 02, 2012 at 06:45:52:
Measure the charging voltage across the battery terminals using a volt meter. Should see about 14.5 volts with the engine at 1/2 throttle or better. Does your alternator have an internal regulator or external? How old is the battery?
Measure the specific gravity in each cell using a hydrometer to see what readings you get. Should see 1.270 and each cell reading should be be close to one another. Hal
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
