Anthony - Could be the milky oil is from condensation from sitting and/or overdue oil change. Try loosening the drain plug and draining a cup or so of oil into a glass container. Only if you see water along with the oil, or the oil is again milky-looking oil does it mean there may be a problem. Otherwise I wouldn't worry about it.
Running hot is likely from a plugged radiator or possibly a stuck thermostat. My experience however has been thermostats tend to stick OPEN which makes the engine run cold.
Another long shot possibility is the water pump driver (the odd spring 'n bolt gizmo on the front of the fan hub) has become disconnected or has gone missing so the water pump is not working.
I would drain and flush the cooling system. Before take a close look at the bottom of the upper radiator tank. If the tubes are loaded with gunk the radiator is gonna need to be removed and professionally cooked out.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
