What I would do: With the loader on the ground, and the engine off, move the lift and lower lever back and forth till all pressure is gone. (assuming the hose goes to the bottom of one or both cylinders) Remove the fitting closest to the valve or coupler closest to the tractor hydraulics. With caution remove the coupler and the top pin on one of the two lift cylinders, leaving it disconnected mechanically. With help, push in on the cylinder while catching oil displaced out of the hose. When the cylinder is fully collapsed, put the hose end in a 2 quart container of Hytran, and pull out on the cylinder rod until it will attach to the loader. repeat on the other side. This should purge the air, or as much as possible, and should allow it to work again. it will firm up as you use it and the motion purges the remaining air. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
