The hydraulics levers are each held on the shaft with a snap ring, there is a medallion on the outside lever that will need to be pried off to get to the first snap ring.
Before taking it apart I would see if this medallion is still available:
p/n 369778R1, or try to remove it without any damage.
after the first snap ring, lever, &washer is removed, it is snap ring ,lever, spacer, washer, on down the line depending on how many valves you have 1, 2, or 3.
I removed my fast hitch from the tractor to prep & paint, so I could get in behind the mounting plates, and all the knooks & crannies on the hitch it self. I did quite a bit of touching up after paint & installation, it's almost impossible to remount without scratching anything, if I had it to do it over again I wouldn't remove it. It's up to you.
This post was edited by rhtx55 at 15:30:00 06/03/12.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
