Re: SMD D264 Rear Main Seal
Posted by sflem849 on June 03, 2012 at 15:38:33 from (166.181.3.157):
In Reply to: SMD D264 Rear Main Seal posted by Dalrymple on June 03, 2012 at 07:26:27:
Well, I went through this two winters ago and it was a major failure. I found a metal retainer from a 450d and used a felt seal. You can't use a rubber seal with the spiral groove from what I have heard. Common sense tells you the groove will tear up the seal. You can't use a felt seal without a spiral or it will leak. That is just common sense.
So I soaked a felt seal in oil and used the metal retainer. All was well for about three hours and now it leaks like a sieve. The retainers appeared to run in the same spot. The crank was smooth from what I could tell. All that and it leaks more than it did with a warped retainer and a 50 year old seal. The only thing a lot of guys say is that it might have spun the felt. Was this because I used the new style retainer with felt??? Maybe
Sorry, no answers in all of this because I haven't had the time and patience to split the tractor again. If you don't mind a hijack, do I have to split an MD with the small clutch to drop the flywheel?
I use a torque table on all bolts that don't have a specified torque in the book. If I remember correctly for a 3/8 NC grade 5 bolt it is 27 ft lbs.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
