Farmall Tractors Discussion Board
Re: Super M hydraulics trouble, two way pressure?
Posted by john d. on January 11, 1999 at 08:34:18:
In Reply to: Super M hydraulics trouble, two way pressure? posted by Johnny Robertson on January 09, 1999 at 19:51:51:
It depends upon which hydraulic system (and attachments) you have. There are two basic systems on these tractors. The very latest ones, including the SMTA models, have live hydraulics from a pump mounted behind the distributor on the right side of the engine. If you have this pump, you can easily set it up for two-way (and live) pressure. Just get the plumbing right and use a two-way cylinder.
If you don't have this type of pump, you have the "Lift-all" system, commonly called a "belly pump", and it DOES NOT provide live-power hydraulics. The belly pump feeds hydraulic pressure through three ports, one on the right side of the tractor, two on the left. The right side port and the front left port are on the same circuit, the rear port on the left side is a DELAYED circuit, designed to provide lift for the rear cultivator gang so it lifts at the end of the row automatically. You can use either front port, or the rear port to raise your disk, but these ports do NOT provide two-way pressure.
There is a way to get two-way pressure from this system, but it isn't pretty. Some of these tractors came with (or received later) a two-way valve which mounted on the filler pipe of the pump. Pressure (usually from the right port) is plumbed to this valve, and the lever for the pump is locked into the "ON" position. Oil is fed to the valve whenever the tractor is running and the clutch is not depressed. From this valve, two hoses are run to the two-way cylinder. In this setup, one lever controlls on-off for the pump, and the other controls cylinder direction.
Post a Followup
: Re: Re: Super M hydraulics trouble, two way pressure?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
