If the carb is lean, and the fuel supply is OK, it needs to be cleaned and a wire run through every passage and orifice. Probably a restriction in the main jet. If turning out the load adjustment screw does not do it it is likely the carb. Thw connection between the intake manifold, and the exhaust manifold can crack, allowing exhaust into the intaks, EGR on the loose. It might be a long shot but worth knowing about. Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
