There are only two screens, one of course is the by pass valve between the two filters whose purpose is to open if hyd filter is plugged or when oil is too thick to pass through the filters. If you have the original style with a thermostatic pellet on it I would throw that away and get the later one with just a spring loaded valve. The only other screen that would effect your lube light would effect a lot more. Later in production of those tractors, a screen was added between power steering pump and relief valve, right in the fitting on end of hose going into valve . This was to prevent complete contamination of entire system if power steering pump fails internally. I have been there, done that on a couple. I would not be immediately concerned if the light will stay out at a moderate speed, say maybe 1200 rpm or so. Then when you get a chance have someone do a complete pressure test on the mcv, checking regulated and lube pressures according to the book. Also, don't idle that tractor down to low idle except for a few seconds. There should be a decal on the windshield or console warning of this. Tears the shock absorbing drive unit up at the flywheel end. The fluid flow from power steering pump , steers first then goes to flow divoder in MCV and operates the rest of tractor controls, like TA and brakes then it lubes parts of trans.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
