Posted by pete 23 on June 07, 2012 at 20:00:23 from (74.32.229.231):
In Reply to: Farmall 450 lpg clutch posted by Farmall450lpg on June 07, 2012 at 12:07:09:
Smoke out of the breather,well, it is either blow by past pistons, coolant vaporizing from oil(but you said oil level was ok) or a hot bearing. I would pull drain plug and check for foreign material. If engine seemed stiff you may just have put enough pressure on crankshaft thrust bearing during assembly to smoke it. These engine do no have a full flow oil filter so stuff goes through the whole lube system if any foreign material is floating around in there. You can pull filter and look for filings also. Sure hope not but can't come up with any other good options.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
