It pretty straight forward. Do one side at a time. Make sure to wedge the front axle. Support the tractor, then remove the wheel/tire. Remove the bolts on the top of the final and remove the fender. Disconnect the pin fron the end of the brake rod that connects to the pedal. Remove the bolts from the lower section of the final. At this point, a helper may be necessary as the final is pretty heavy. Sometimes it will pull straight off, and sometimes it will require persuasion from puddy knives driven between the final and transmission/axle extension to get the final loose. Pull straight out with the final as to not damage the transmission seal, taking the brake band, toggle and rod with it.
Now that you have it apart, install the new band. You may have to reshape it some to get it to fit around the drum. Then reinstall everything in reverse. The right side is a bit more difficult because of the longer differential shaft that extends through the axle extension. Once both sides are done, adjust the rod so that the pin will just slide in. Take the tractor for a spin working the brakes on both sides pretty good, then readjust each independently so that they have the same stopping pressure and travel.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
