Posted by Bob M on June 09, 2012 at 16:56:55 from (69.207.87.163):
In Reply to: 450 coil posted by P and R Pete on June 09, 2012 at 16:24:12:
A coil running too hot to touch says you've got 6 volt coil being fed 12 volts!
Wiring a ballast resistor in series between the ignition switch and the coil primary will solve the problem. Or replace the coil with a 12 volt coil (it will be marked "no external ballast resistor required" or similar....)
Incidentally a properly operating coil will become only a bit warmer than the metal distributor housing. Ie. it will be cooler than nearby engine surfaces.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
