Posted by dstates on June 09, 2012 at 20:24:00 from (173.27.246.62):
Well, I went ahead and replaced the plug wires, distrubutor cap, rotor, points and condensor and now I have spark!!!!
So then I turned the fuel back on and got nothing at the carb. A little investigating found that the inlet of the sediment bowl was clogged. The tank has a layer of crud at the bottom and it just drains right into the bowl. Some pieces of rust look to be the size of a nickel.
So I think I've got 3 options:
1. Remove the tank and have it cleaned and sealed before I go any further.
2. Do #1 and rig up a small temporary tank so I can still get it started.
3. Add a "snorkel" to the sediment bowl inlet so I draws gas from above the layer of crud until I'm ready to tackle the tank.
If I can come up with an easy way to do #3 I'll probably go that way, but #2 is probably the best answer.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
