Farmall M shift cable
Posted by high53 on June 17, 2012 at 07:34:57 from (71.33.126.3):
I have 1942 farmall M ( has been in the family since new) It Runs good but the cable that shifts the overdrive 9 speed is stuck. I can only use it as a 4 speed with the road gear. I need to replace or get it unstuck. It has not been shifted in over 25 years. Does anyone know if it can be disconnected and remove by removeing the plate on the bottom of the case. It enters the case on the right side thru a hole just forward of the belt drive. I have tried all sorts of Kroil oil and no luck. I think I need to replace the cable. I am hoping it can be removed without going into the transmission. any pictures would be nice. Thanks
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
