And while we're at it - if you DO decide to go with the kit (which can help clean up slop in the steering) Most of the stuff is pretty straight forward - really only one way it can come out and go in.
However, the old brass bushings can be REAL tough to remove. The best way I found to get them out was to take a hacksaw blade - insert it through the hole and cut the bushing lengthwise all the way through - you can nick the cast iron without causing a problem, but obviously keep it to a minimum.
It's best to make two opposing cuts - then the remaining bushing halves will knock right out with a chisel.
Your oil seal on the top of the steering box where the steering shaft goes through is probably a double thickness leather seal. The new one will be half the thickness, don't let it concern you - try to seat it flush with the top of the hole - you'll see what I mean when you get it.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
