Re: 350 rear chassis ?
Posted by riverbend on June 20, 2012 at 10:28:53 from (74.37.48.35):
In Reply to: Re: 350 rear chassis ? posted by D Slater on June 20, 2012 at 08:42:53:
When I bought the tractor the TA was out. The rollers were all flat sided and crossways, so no surprise there. The cross shaft for the TA throwout bearing had been cut and rewelded. The top arm had been shortened by about an inch.
I put a rebuilt TA, new clutches, and a different cross shaft in. The TA didn't work. With the TA pressure plate bolted up to the TA clutch basket the pressure springs were completely compressed. There was no way the pressure plate could lift and release the TA clutch.
I made up some 1/8" shims to put between the pressure plate cover and the clutch basket. That gave it enough room to release and got the TA working. The clutch does not release by much (0.020 - 0.030") and it is still hard to shift. If there is any load on the transmission, the shift lever sticks in gear. No amount of adjustment will make it right. I have done it by the operators manual and by the service manual. Neither makes any difference ( nor are they that different).
Something is not right with this tractor. Sometimes when there is an odd problem like this, it is due to a previous repair that was not quite done right. One big thing that was replaced was the rear chassis.
So, I'm wondering if there is anything in the rear chassis that would make a difference with the TA ?
Greg
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
