Thank you. I have ordered a kit with all of the parts you mentioned. At this point the tractor is not wired, I have a battery sitting on the floor with jumper cables to connect it to the tractor. I had the - cable to the frame rail and the + cable to the resistor with the other end of the resistor connected to the coil. I am not sure if that is proper or not based on what you said. I am turning the engine with the hand crank. The whole tractor needs to be rewired but if I need to split it I'd rather do that first. I don't need to be able to move the tractor right now, I'm just hoping to get it running so I can find the squeal that the PO described and also see if the hydraulics and IPTO work. I did drain the oil and look at the seasonal disconnect, which seems to be in fine shape so I guess that is not the problem. Zach
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
