As i was setting on the pourch i got to thinking on how i made them brackets for the 06's . Like i said i used a couple pieces of 8 inch channel iron and cut the one lip off leaving the one to the rear, then i cut four pieces of angle iron to conform to the angles on the axle housing and the u/ bolt that i had made conformed to the angles of the axle and each side used two U/ Bolts. Then ya make up the tabs that ya bolt the sub frame to with the two 1/2 inch bolts . Ya remove the three point hitch arm if it is three point and if it is a fast hitch ya have to remove the lower fast hitch bundle .Ya install your drive sprocket and adjust the driven sprockets to line up and install the drive chains , then ya back into the husking bed and hook it up and once that is done then ya drive into the gathering unit flip the clamps down over the axle brackets hook up the lift cylinders and and the drive shafts and go to the field.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
