Re: Quick IH756 Hydraulic help
Posted by pete 23 on June 20, 2012 at 19:54:31 from (74.32.238.2):
In Reply to: Quick IH756 Hydraulic help posted by nw_bearcat on June 20, 2012 at 19:30:47:
I would flow rate the pump. If that is not a possibility, you might just slip in a higher pressure relief valve from a newer tractor. You could go from 1600 psi to 2200 psi. With a small cyl diameter that may be your problem. Relief valve is located in seat support, right side, has 1 1/8 in hex head, about 3 inches long with screen in inside end.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
