The 29 spline part should slide off the regular IH shaft, Unless its stuck or rusted. The inside shaft of the splined sleeve is a regular M splined shaft. Bearing cage is regular IH and can,t be completly removed from the transmission housing without moving the bull gears out of the way inside the gear housing. Like Jim said there's a bolt in the shaft end. I just thought you already removed it. Also plate the inside brake disc contacted needs unbolted and removed before installing the band brakes. Put the parts tractor bolts back in the housings.
This post was edited by D Slater at 13:03:20 06/21/12.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
