Posted by Janicholson on June 23, 2012 at 07:30:44 from (96.24.99.126):
In Reply to: H ampmeter jumping posted by j hakenwerth on June 23, 2012 at 05:55:40:
Mechanical voltage regulators are electrically noisy. They produce variations involtage output that ---average--- the desired charge voltage and current. from a millisecond to millisecond view, they produce voltage from below bat voltage, to twice the bat voltage. Batteries and lights do not care as long as that average is ok on a second to second basis. Amp meters of best design use a resenous liquid on one of the pivots for the needle. This sticky viscous material dampens the needle fluctuation and produces the steady needle showing an average charge rate. (This is not the only method, but common) The electronic controls of newer equipment and cars (if equipped with a gauge) would need much less dampening if any. Original meters can and do have this material dry out and stop working, new less expensive meters don"t even have it. Thus your viewing the needle jumping around might be irrelevant but distracting. Swinging through full scale side to side is an indication of connection problems, or generator/VR issues. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
