Re: Super A to 123 motor
Posted by El Toro on June 23, 2012 at 14:41:02 from (108.3.225.57):
In Reply to: Super A to 123 motor posted by Charllie in MO on June 23, 2012 at 13:10:22:
You buy the C123 sleeve kit and it can be installed in your Super A block without any machining. You need to measure the length of old sleeves. If they measure 6-7/8" in length you can only install the C123 kit.
Some of the Super A's came with C123 engines and have the 354898R1 engine block. Those sleeves are 7-1/16" in length and you can install an oversize kit to give you 133cid. No machining is needed to install them. You also need to clean that block area where the old sleeve seals are installed. Buff off any rust in that area and vacuum any rust scale in the block. Coat the
new sleeves with a light coating of dawn so they slide thru the new seals easily. Hal
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
