Posted by CNKS on June 24, 2012 at 08:33:12 from (216.144.104.128):
In Reply to: SH hydraulic question posted by oregonfarmer on June 24, 2012 at 06:46:56:
Not likely. Engine driven pump with reservoir under gas tank or belly pump? Engine driven does not have a reservoir dip stick. I just reassembled the one under the gas tank, without looking at the diagram, I imagine the release in the belly pump is similar. That is not a particularly easy repair when reassembling. Lift the lever up and push, banging on it is making the problem worse as you have two metal parts contacting each other. You must have worn a groove in one of them, but I would think you would have the opposite problem, that is not holding. How long has this been going on -- the previous owner may have put a stiffer spring in the hole it fits into.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
