Posted by wayne in mn on June 24, 2012 at 18:29:16 from (24.179.181.245):
In Reply to: Farmall Brake Drum posted by TMonton on June 24, 2012 at 18:21:44:
Larger hole had the nut welded in with the jam nut & adjusting screw. The screw supports the bottom of the brake band so the brake doesn't drag. Install the brake band, adjust the free play, apply the brake fully & lock in place. Loosen the jam nut, tighten the screw then back off 1/2 turn and lock the jam nut. Small hole is for drainage of liquid.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
