Posted by pete 23 on June 24, 2012 at 19:28:27 from (74.32.238.2):
In Reply to: SH hydraulic question posted by oregonfarmer on June 24, 2012 at 06:46:56:
Try the other outlet. If you look at the parts diagram of the Super H hydraulic lift all, regardless of which one you have with belly pump or live pump, you will notice two different styles of check valves holding the load up. The one they call a differential check valve has a much smaller ball and therefore when holding heavy loads it is much easier and smoother too release to lower the load. If you are using two hoses, one on each side of what ever your are holding, you will have to T the two together to use the single outlet. I have over the years installed that style check valve to overcome just that problem you are having. If your H should happen to not have that small ball set up you can install it but you have to make sure the pin operating the ball is correct length so as to hold the load up when lever is in neutral position.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
