As Jim says, the valve timing is designed so the flow to the side of the valve that will be the "out" or pressure side is there before the "in" or return side opens. This prevents the cylinder from moving slightly in the wrong direction as the valve is moved. Because the "in" side is not open yet, or less open than the "out" side, the pressure is relieved over the relief valve, and they have tendancy to vibrate when barely opening or "cracking". Some relief valves can be pretty noisy or vibrate badly when cracking. You are lucky the hydraulic systems of that era are fairly low pressure.... a 5000 psi relief valve can have a really loud squeal :shock:
Part of the noise is induced by the gear teeth creating pulses, and in some systems they set up a resonant frequency that aggravates the noise. You may find the noise is worse at some engine RPMs than others.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
