the ends are either carboned up or swelled up when they burnt out. if there carboned which you wont know, is spray some carb cleaner in past the threads so it work its way down to the tip. then just keep turning and pulling up at the same time you should make headway slowly by doing this. if the ends are exploded then you have to remove the injectors. or either way injector removall may be the only option. then make sure that you replace all the sealing rings and dust rings and take notice that the cup is marked "up" and this has to be installed at 12 oclock position. failure to follow this will result in hard and poor starting.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
