374262R91 was a distributor shaft, 2 springs and the pin for the distributor shaft gear all under the one #. Parts are sold individually now. Shaft 362723R91, springs 372785R91, and the drive pin 70916202. If the firecrater pistons check out okay I use them with new sleeves. Figure there made out of better stuff than the replacements. If decided to use lower compression and the tractor never worked hard the 30 degree original SM advance could probably be used. Looked for a note of the advance rate springs used with the original 374262R91 kit. Didn't find where it was at the first look. Yes the L22 means the distributor will advance from 0 up to a total of 22 crankshaft degrees if everything is correct. In case something was off a little IH wanted you to play it safe and set the time at 22 with the engine at full RPM and let the low speed time fall to around 0. Templet to mark the front engine pulley for 22 degrees was in a firecrater kit. Think I can get a NOS distributor shaft at a lot better price than a dealer if you decide to replace.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
