The 504 has two PS systems. Probably depends if it is rowcrop or utility. One system is hydrostatic with the valve at the end of the column, a flow divider, and a hydraulic relay that supplies directional power to the front axle.
The other system is a Charlynn Torque Generator directly below the steering wheel. Not sure where the power comes from. Perhaps a piggyback pump next to the main pump.
I put on a system on a non PS Farmall 504. I used a Charlynn TG right at the bolster. Power comes from a C, 100, 140 or similar hydraulic pump. That's a bolt-on installation below the distributer. 1/4" of the frame channel top flange has to disappear. The Charlynn required a bracket and a coupling. I suppose the Charlynn could go on any of the 4 (?) steering shafts. The closer to the bolster is the best arrangement when one considers the crappy U-joints and shaft bearings.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
