The tierods can be adjusted for play and if they are egged shaped a little work with a disc grinder they can be rounded again. The steering sector mite need some bushings,seals and a bearing. The output shaft also mite be loose. You realy need to start with the steering secteor first then work back to the tierods and bearings probably just need to be repacked and adjusted. Check the spindles to make sure the grease is getting to the bottom. Ive done a bunch and ended ip with good results.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
