Re: Narrow front wobble fix??
Posted by mkirsch on July 01, 2012 at 04:40:56 from (67.253.161.186):
In Reply to: Narrow front wobble fix?? posted by lbg57 on June 30, 2012 at 18:57:31:
You can get rid of a lot of the wobble without replacing the gears.
Check your U-joints. Easily replaced for a few $$.
Replace the bushings on the vertical shaft.
On mine the sector gear was loose on the shaft. I used an empty pepsi can to make a shim.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
