Posted by P and R Pete on July 05, 2012 at 19:53:32 from (159.240.11.159):
In Reply to: Farmall A steering posted by charlie M on July 03, 2012 at 17:10:11:
Charlie, there's been a lot of talk about these over the years. There was a gentleman here named Hugh MacKay (who since has passed away) who was very familiar with SA steering problems. I was able to find some of theses discussions by typing in 'Hugh MacKay- steering' in the search feature.
...and here's two posts he's written about SA steering...
"Bob: If Steering shaft has not end to end movement the worm and bearings are fine. Castle nut can create the problem, but by the time that happens the woodruff key in the steering control arm is probably out of shape. 90% of these I've dealt with had nothing more wrong the the two woodruff keys on that vertical shaft, the one I mentioned in steering control arm and the one oin the half gear turned by the worm. Those keys alone can give 1.5 free turns on the steering wheel, if badly worn."
and...
"If the steering shaft has no end to end movement, I wouldn't touch that big plug. All you will correct by removing that is bearings on the shaft and if it has no movement the bearings are good. If the bearings on the steering shaft are tight then your problem is woodruff keys on the vertical shaft that comes out bottom of steering box. The steering control arm is keyed to shaft and the gear inside is keyed to the same shaft. I have seen those two keys loose enough to give 1-1/2 turns of free travel on steering wheel. Only way to fix that is remover front axle, then bottom half of steering box. Usually the keyways require cutting larger and use larger keys."
Now, I'm not saying that this is your problem, but just some food for thought. I have an SA with the exact same problem, and I hope to tackle it this summer. Try searching for some articles, and good luck.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
