Posted by doehmke on July 07, 2012 at 07:17:23 from (67.233.244.36):
What's the best option to replace the ring gear on an F-20? I bought an extra engine for the starter parts, but the teeth on the ring gear are gone for several inches. I took the flywheel in to have it resurfaced and they offered to remove the ring gear. Unfortunately that meant cutting it off, so there's no option to rotate it on the flywheel. Though I suppose it could be welded...
I have a Farmall M ring gear that is almost identical, except the bevel on the teeth is on the opposite side from the original on my flywheel. Can I use the M ring gear as is? Or do I need to grind bevels on the correct side of the teeth so the starter drive can engage correctly?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
