Posted by Janicholson on July 07, 2012 at 13:40:14 from (96.24.99.126):
In Reply to: Farmall A idle miss posted by kopeck on July 07, 2012 at 12:48:09:
first since it is consistant, Use a spark plug from the good running engine. put it onto #1 plug wire and lay it on the block. if two cylinders now misfire, go to the next plug toward the rear. WHen it only misses on one cylinder, you have found the one causing the grief. Replace that plug with the one you know is OK. If this makes the mis go away, the plug was bad. If it still misses, I would next adjust the valves correctly and see if that is the answer. Pay attention to the adjustment on the cylinder that misses. The only last item I can think of without being there is to see if the intake manifold is cracked internally allowing exhaust to get into the intake, leaning it down at high vacuum. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
