Broken camshaft gear (crankshaft timing)
Posted by Mark Alayne on July 08, 2012 at 07:40:25 from (97.73.64.155):
I posted about my Super M quitting and not starting again. (titled: crankshaft timing) Several of you indicated a camshaft gear issue. Nut backing off, broken gear, or key way problem. After reading my manual I see that the camshaft gear drives the distributor drive gear. My rotor turns "normally" when cranking engine. Does this still indicate I have a broken camshaft gear? I still have a thunk coming from the engine somewhere while doing this. Any more ideas about what is going on? Since it has cooled down here in Kansas I will pull the dist./hyd pump unit once I get it into the barn. I saw a post about feeling looseness on the gear from in there. Thank you in advance.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
