You can adjust them with the engine at an idle. It would be easier to have one person with the feeler gauge and a helper doing the adjusting.
You also can jack up one of rear wheels as been mentioned and place the tranny in 5th gear after removing the plugs. Have the helper to rotate the wheel while you hold your thumb over the plug hole until feel pressure. Then drop a long plastic straw on top of the piston and then you watch the straw rise while the helper slowly turns the rear wheel. When it quits rising you can now adjust valves 1-2-3 & 5 counting from the fan end of the engine. Once these are adjusted to .020" rotate the engine 360 degrees and adjust 4-6-7 & 8. Hal
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
