Posted by El Toro on July 09, 2012 at 04:18:02 from (108.3.148.85):
In Reply to: 460 starting problems posted by reddog300 on July 08, 2012 at 20:39:14:
Since it will start while holding the starter button I think you have a defective ballast resistor between your ignition switch and the coil. You should also have battery voltage on the terminal on your ignition switch that feeds voltage to your coil. Use a volt metter and check for battery voltage when the switch is in the on position. If there's no voltage on that terminal to your coil you need to check your switch to see if voltage is being fed to your switch. If there's voltage being fed to the switch you probably have a defective switch. Hal
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
