Posted by mkirsch on July 09, 2012 at 06:29:22 from (64.80.110.75):
In Reply to: 460 starting problems posted by reddog300 on July 08, 2012 at 20:39:14:
Unless this is a really tiny battery, ONE hour of running would not drain it down to 10.3 Volts. We've run tractors for 2-3 entire DAYS just on the battery.
Even leaving the ignition key on for another 3 hours would not drain it that far.
You've got a MAJOR drain on the battery somewhere, or a faulty battery.
Unhook the battery, charge it up, and leave it sit disconnected overnight. Measure the voltage the next morning.
As it is, I would leave the battery unhooked when you're not using the tractor until you find the problem because you have a MAJOR draw, probably a short circuit. Could be a risk of fire there if you've got oil/gas leaks.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
