There isn't anywhere on the tractor that 5 gallons of oil could go in a day's use and not cause an OBVIOUS problem.
If it's getting into the top end of the engine, it would smoke like a freight train ALL the time at the very least. If it's getting into the bottom end of the engine, it would be running out the breather in a stream. If it were somehow transferring into the cooling system, the coolant would be running down the side of the tractor.
The odds of any of that happening are astronomically small. There is no direct interface where the hydraulic fluid in the rear end could transfer UNDETECTED to the engine.
Two possiblities:
1. Someone *IS* stealing the oil.
2. The oil is leaking out only when the tractor is out in the field.
What do you do with the tractor when you are using it?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
