Posted by Bruce Brittain on July 13, 2012 at 04:09:06 from (4.157.8.67):
There is way too much slop in the steering of my Super A. I have tightened up the tie-rod ends, and the steering column does not crank in and out when it turns, so I suspect that the problem is slop in the worm and sector gears, rather than end-play in the steering column bearings.
Is there any way to reduce the amount of slop? I can't find anything in the shop and owner's manuals indicating how to do this. Will I have to replace the worm and/or sector with new components? The sector is brass, so I suspect that that is where most of the wear has occurred. If I replace the sector, should I replace the worm, too? (Replacing both mating gears generally seems like a good idea, but it appears that to replace the worm I would have to replace the whole steering column, which won't be cheap...)
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
