It is unlikely that a copper washer would do the job because it is not an acual plug. There is still path to seep oil between the screw and jam nut threads.
I just took a WD-9 steering box apart last year. The tractor had spent much of it's life outside and I noticed in winter that the steering was frozen so it had some water in the steering box. That may have contributed to the oil leak since it was overfilled with oil/water.
Just my opinion here but it is really hard to completely stop all oil leaks on these old tractors. I have read posts from other members and even on completely rebuilt tractors they still have some minor oil leaks. The trick is to figure out which ones can be obviously fixed, like worn bearings/bushings/shafts. In the case of your steering box it probably wouldn't hurt to take the side cover off, clean it out, and replace the oil. While you are at it, it is a good time to change the seal on the output shaft because those do seem to leak too since they are the old leather seals. Maybe you can seal the adjusting screw & jam nut with some of your favourite sealant.
I have a WD-9 with pinion shaft seal leaks right now and the brake bands are a mess. I was going to change the seals and after I took the brakes apart I found the pinion bearings are in bad shape too so I put it back together until a time when I can get by without that tractor for a few weeks. Those will be a pain to change. How do they look on your tractor?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
