Posted by Janicholson on July 15, 2012 at 11:25:42 from (96.24.99.126):
In Reply to: Carb cleaning posted by BigTone on July 15, 2012 at 11:12:22:
Shut off the fuel! Remove the bowl. clean the bowl out with carb spray and set it aside. Look at the float. It should be hanging down at an angle. put a coffe can or pan under the carb and turn on the fuel a little. Fuel should run out of the area where the float pivots. Now while it is running out, lift the float gently with one finger till it gently stops. All fuel flow should stop. (just like a toilet tank float). If very gentle pressure stops the flow, I would put it back together and give it a try. if the float is heavy, it could have gasoline inside it, if it does, it is in need of replacement unless you are a very acopmlished solderer. If it is dry inside and the fuel still comes out when lifted, the needle and seat need to be replaced. The needle will probably have a Viton (rubber) tip. The old one may not. Be sure the little spring is correctly hooked on the needle, and the push plate of the float. Next is float level. The specification is in the info in the kit. it can be done installed especially if yoy measure the distance of the old float, and get in mind how it needs to be to shut off the fuel. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
