WD-9 Radiator Mounting Pads
Posted by WD9ER on July 18, 2012 at 06:26:48 from (65.127.84.74):
I am working on mounting my radiator on my WD-9. I constructed 1.5” OD X 0.25” thick rubber mounting pads to go between the bottom of the radiator and chassis. When I get everything mounted and back together, the radiator appears to be sitting too high based on the alignment of the upper radiator hose. The main issue is that the lower fan blade hits the fan shroud. Does anyone have any experience with this? If so, what have you done to work through the issue? If I removed the rubber mounts and go directly metal-to-metal, which is not ideal for a radiator mounting setup, I believe I would have clearance.
Below is the page out of the parts book showing this joint. third party image
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
