I am going to tell ya something about setting valves , Tryen to get a hot set is anything above 70 degrees even IF you run the engine on a dynoand get every thing up to running temp by the time you pull the valve cover get your screw driver , wrench and feeler gauge get it set to TDC the valves are already cooling down and adding .003 to the set all your going to have is loose valves. Valve setting is a ART as the way i set will not even be close to your set and most people do not look while they are setting for BRIDGING of the feeler gauge and there for there set is WRONG and so far off that ya could throw a cat between the valve stem and the valve . I can set valves to give you better bottom end or better top end . If the engine is above room temp set them to spec's.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
