I have to agree with that. You can never get the valves really set hot with a standard feeler gauge. The temperature drops considerably between adjusting the first valve and the last. I prefer motors that give a cold setting. All clearances are set at equal temperature and there is no chance of burning your hands or arms on hot engine parts. We set the valves on the Farmall H a couple of weeks ago. Very easy with magneto ignition.
1). Remove the high tension lead from the magneto cover to the centre of the distributor cap.
2). Get the motor to top dead centre on Number 1 cylinder.
3). Set valves on Number 1.
4). Turn motor 180 degrees (until impulse coupling trips). Set valves on Number 3.
5). Continue the same through 180 degrees for Number 4 and Number 2.
Then check and reset them all again as necessary, having turned the motor over several times. This ensures a much better setting than just going through once.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
