You might be able to get by using the gasoline flywheel and D560 starter.
The gas flywheel has a little larger diameter ring gear and uses a starter drive with either a 29mm or 32mm OD gear. The diesel starter uses a 32mm OD gear for a hydro tractor and a 36 mm OD gear for a gear drive tractor. The 560 starter will have a 40mm OD gear. I don't know for sure if the 560 starter end frame will bolt in to the 656 housing but the drive problem could be solved but switching to the correct dimensional drive gear.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
