Thank you very much for your help. Yes, the clutch felt good to me. I will know better once I am able to use the throttle and try out 4th and 5th gears. I wasn't able to adjust it quite as you had said because the pressure plate has a center hole with splines that run the IPTO so there was not a way to measure directly from the fingers to the flywheel surface. I just checked that they were the same height above the surface I was able to see and decided that would have to do. I was able to follow the detailed step by step instructions on how to adjust the main clutch and TA clutch linkages and that seems to have worked out well, the TA operates very easily and smoothly. I am sure I will keep having more questions to ask as I get closer to having it all back together. Zach
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
