Re: Bad noise in 5th gear on M
Posted by Bob M on October 04, 2000 at 11:29:57 from (192.232.120.194):
In Reply to: Bad noise in 5th gear on M posted by S-E Michigan Part Timer on October 03, 2000 at 15:35:55:
Denny's right that 5th is "direct". Power runs straight thru the transmission on the mainshaft. No countershaft gears are involved - only the countershaft drive gear is in mesh, and it's carrying no load in 5th.
The noise you're hearing is probably either worn or bad mesh between the differential bevel pinion and ring gears, or a bad bearing on the trans output shaft. You only hear it in road gear as these parts are spinning several times faster than they are in the lower gears.
Post A Followup
: Re: Re: Bad noise in 5th gear on M
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
