Posted by Rootsy on July 23, 2012 at 19:52:41 from (174.124.167.104):
Started off with replacing the left side outer axle seal which opened up a real can of worms... Going to be an expensive morning tomorrow... Inner and outer axle bearings, pinion bearings, bull pinion bearings... seals... gaskets... To think she made the 20 mile Mackinac Bridge ride in 2009 and aside from a little oil leaking out of the housing and onto the rim now and again sounded fine... Internally, it sure isn't. Ring / Pinion backlash is about 60 thousandths, minimum, and the roller bearing supporting the end of the pinion was GONE, the rollers were in the bottom of the case. The ball bearing wasn't far behind... Lucky it didn't grenade... Though the right bull gear is newer and tried to eat it's way through the rear-end housing at one point in the past...
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
