Posted by Owen Aaland on July 23, 2012 at 23:02:15 from (216.47.35.39):
In Reply to: 1586 DataCenter posted by farmboycitygirl on July 23, 2012 at 06:58:42:
With your symptoms I would not automatically decide the problem is with the data center.
The engine speed and PTO speed both rely on the sensor reading the flywheel ring gear teeth. Check the sensor for continuity. It should not be an open circuit. Someone else may chime in with an average ohm reading for a good sensor.
The Speed signal is an indication of a weak sensor, adjusted too far from the gear, or too much resistance in the wiring or connectors.
The exhaust temperature readings could also be a poor connection or a bad sensor in the manifold.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
