Posted by Hugh McKinney on July 24, 2012 at 09:10:44 from (75.106.0.53):
In Reply to: M engine removal posted by BigTone on July 24, 2012 at 07:40:03:
Let me tell what I learned the hard was a year ago pulling the engine out of my 450, which is almost identical mechanically to an M: It will be a LOT easier if you bring some help, and two, take you some 5/8 and 3/4 inch all thread with nuts and washers to go with them, plus a good hack saw. This will enable you to make bolts that you can screw into the sides of the front bolster, the side rails, and the bellhousing/frame of the tractor. No, you don't need to remove the clutch, but you do need some really good jack stands and heavy lumber to support the frame/bellhousing of the tractor when you are removing the engine, and yes, you really should remove the front bolster, and it is very heavy and thus dangerous, especially because it also holds up the rest of the tractor. Get some really good help and protect yourself from real harm. Good luck.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
